2006 Chrysler 300 oil press
ROBOVEGI
Engine Performance problem
2006 Chrysler 300 6 cyl Two Wheel Drive Automatic
I am in the process of installing an after market oil pressure gage on my 3.5 litre v-6, here is the question. I need to know exactly where the the oil port plugs are that i can tap into for my sending unit. I do not want to end up pulling a water plug. If there is more than one oil plug i need to know that too so i have more options. Rob O.
Sep 22, 2009 at 2:57 PM
  • 75,988 POSTS
Thanks for the donation 6 cyl 2.7L engine the oil pressure switch is located on the right side of the engine block-see below
https://images.2carpros.com/forum/automotive_pictures/12900_27_oil_pressure_switch_1.jpg
Sep 22, 2009 at 3:36 PM
