2006 Chrysler 300 oil
TREYWILL
Electrical problem
2006 Chrysler 300 6 cyl Two Wheel Drive Automatic 77k miles
oil pressure switch need to be changed ....what do i need to do it ?
May 7, 2010 at 7:59 AM
BLUELIGHTNIN6
  • 16,542 POSTS
You vehicle uses an oil pressure sensor, not a switch. Changing the car's oil pressure sensor involves locating the sender, removing the connector, backing out the hex, putting a new one in and then tightening it. Pretty simple repair and limited basic mechanic tools needed.
May 7, 2010 at 8:02 AM
