Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Chrysler
300
Drivetrain
Transmission
Fluid
Leak
2006 Chrysler 300 Leaking Transmission Fluid
2006 CHRYSLER 300
57,000 MILES • 6 CYL • 2WD • AUTOMATIC
WANDA JOHNSON
MEMBER
1 POST
Is there any way to know if it can be fixed by someone other than the dealer.
Feb 25, 2009 at 10:15 AM
Experienced Mechanic
I need you to clean the trans and determine where the leak is coming from. Chances are it is the trans pan, and it is a cheap and easy fix.
Let me know what you find.
Mar 15, 2009 at 3:41 PM
🔧 Tools & Auto Repair Parts
Shop on Amazon →
Add image or video
Ask a new question
Engine won't start
Check engine light
