2006 Chrysler 300 Leaking Transmission Fluid
2006 CHRYSLER 300
57,000 MILES • 6 CYL • 2WD • AUTOMATIC
WANDA JOHNSON
Is there any way to know if it can be fixed by someone other than the dealer.
Feb 25, 2009 at 6:15 PM
  • 110,194 POSTS
I need you to clean the trans and determine where the leak is coming from. Chances are it is the trans pan, and it is a cheap and easy fix.
Let me know what you find.
Mar 15, 2009 at 10:41 PM
