how do i change a bad headlight ballast on a 2006 chry.
300c.
Mar 3, 2010 at 11:05 AM
AUTOMD
MEMBER
swap the bulbs left to right and see if it continues. its easy to do, remove screw, turn cap and its off, there's a little pin type of clip and you get that off bulb comes out, only hard part is putting that pin clip back in.
