2006 Chrysler 300 EGR valve
85,000 MILES • 6 CYL • 2WD • AUTOMATIC
BRUCE DAHM
MIL has been off and on for about 3 tanks of gas. Recently pulled code is P0406. TSB #1802707/TSB Item #10021686 summary refers to EGR valve, but have not accessed complete TSB document. I need a new EGR valve? If so, I need to pull intake manifold which involves pulling crossbrace at rear of engine bay to replace EGR valve? Chilton's not much help due to too little detail.
Sep 11, 2010 at 7:48 AM
ERNEST CLARK
  • 1,730 POSTS
I can give you the entire procedure for replacing your egr valve, but first I'll need to know the engine in your car. (2.7 or 3.5)
Either way, you'll have to pull the "Upper" intake manifold and the shock tower crossbrace.
Sep 14, 2010 at 12:46 AM
