2006 Chrysler 300 delayed start
50,000 MILES • 6 CYL • AWD • AUTOMATIC
TFURD
When I turn the ignition key, nothing happens for about one second, then it starts normally. This just began happening yesterday, was normal immediate start before. is this signaling something to get worse?
May 21, 2009 at 5:33 AM
RACEFAN966
  • 5,029 POSTS
I would check the starter relay. It may be sticking and not engaging as should. If the car has a warranty then use that first if not and you need help checking it out then get back to me and we will go from there.
May 22, 2009 at 3:32 AM
