2006 Chrysler 300 Can't get car to shift out of park
10,286 MILES • 6 CYL • AWD • AUTOMATIC
ANTHONY4M
my car is stuck in park, I can't shift into another position. What could be the problem.
Apr 22, 2009 at 8:40 AM
2CARPRO JACK
  • 11,533 POSTS
First check all fuses. Then see if the brake lights work.If not the brake light switch is out. I have also seen the shifter itself go bad internally.So if all is ok, you will need to pop the top plate off the shifter and see if is all moving internally
Apr 22, 2009 at 8:54 AM
