2006 Chrysler 300
LADY921
  • 2006 CHRYSLER 300
Electrical problem
2006 Chrysler 300 6 cyl Two Wheel Drive 75000 miles
All of the lights on the instrument panel blinked on two or three times while driving. The gauges for the odometer, tachometer, fuel gauge all dropped and didn't return to working condition for about 10 seconds. What is causing this problem
Friday, January 8th, 2010 AT 9:38 AM
CARADIODOC
  • 33,916 POSTS
Your instrument cluster is no longer the simple, reliable, trouble-free set of gauges and lights it was years ago. It is now a very complicated computer board that runs a lot of stuff in the car. If you're real lucky, the problem might be due to nothing more than loose connector pins on the back, but that's just a guess. This was common on late model Caravans but I don't know if that style of connector is still being used. If it is, the pins can be soldered to the copper circuits to fix the intermittent connections. If by some small chance I'm right, the problem is likely to act up more frequently in the future. It won't magically fix itself.
Much if the information used by the instrument cluster comes from the body computer. They also can cause intermittent problems but it is more common for them to just lock up and go dead. For that symptom, disconnecting the battery for a minute or two often resets the computer.
Caradiodoc
Sunday, January 10th, 2010 AT 3:15 AM
LADY921
Thank you caradiodoc. I appreciate a response from you on this sistuation. Do you know anything about oxygen sensors for the same car? I was told my vehicle is in need of one. I would rather purchase it than have it installed. This would be cheaper on the pocket.
Monday, January 11th, 2010 AT 9:56 AM
CARADIODOC
  • 33,916 POSTS
There are at least two of them; one before and one after the catalytic converter. There could also be a second pair if the exhaust system is divided into "bank 1" and "bank 2".
When the engine computer detects a problem with a sensor, it will set a diagnostic fault code in memory and turn on the Check Engine light. The code description will indicate which sensor has the problem. There were a few brands / models of car where the code indicated the incorrect sensor.
You'll need a wrench or a special deep socket with a notch on the side to remove these sensors. If it feels tight as you unscrew it, the threads are starting to peel out of the exhaust pipe. Work the sensor back and forth to try to free it up. The new sensor will have silver anti-seize compound on the threads. Don't wipe that off.
Caradiodoc
Monday, January 11th, 2010 AT 12:21 PM
LADY921
I checked the maintenance slip and it doesn't give the diagnostic code for which oxygen sensor needs replacement. I must check up on the dealership because they will try to overcharge just because I'm a woman. I don't know what area u are in but I'm in NY. It's probably a slim to none chance that u may know of a good auto mechanic in one of the five burroughs of NY. I thought I'd give it a shot anyway. I appreciate ur responses caradiodoc.
Tuesday, January 12th, 2010 AT 2:55 PM
CARADIODOC
  • 33,916 POSTS
All dealerships and many independent shops use a book called the Flat Rate Guide. It spells out exactly how much time to charge for performing specific tasks such as replacing a sensor. Body shops do the same thing, so estimates from different shops should be the same. The only difference will be due to different shop hourly labor rates, additional parts or services, or cost of parts depending on where they were purchased.
The advantage to flat rate is every customer is charged the same amount, AND every mechanic is paid the same amount, (in hours). If due to experience, training, or investing in special tools, he gets the job done faster, he gets paid the same number of hours. If he hurries too much and does something wrong, he gets to fix it or do it over for free.
Think of your neighbor's kid mowing your lawn for ten bucks. It doesn't matter if it takes him all day with a scissors, or two hours with a lawn mower, he earns ten bucks. Would you be angry if he invested in a riding lawn mower and got done in one hour? It's still ten bucks, but he can mow more lawns in a day. A lot of people incorrectly think they got ripped off when they were charged for four hours when their car was done in three hours. They're the same people who complain when they were quoted, (and charged) for four hours, but the job took five.
Thinking you're being charged more than someone else isn't a woman thing, it's an uneducated consumer thing. Guys are just as likely to feel they were over-charged when they don't understand how repair shops and their cars work. Gone are the days when backyard mechanics could do any job a lot cheaper because they didn't have to pay all the taxes, insurances, hazardous material recycling charges, and shop upkeep.
There may be times when someone will be charged less than you because they know more about cars. As an example, you might buy a set of tires, and they notice the old ones had bad tire wear, or your brake pads are almost worn out. It should be easy to convince you to have the additional work done. They are actually looking out for you in the long run while generating more business for themselves. Since the wheels are already off, it will take less extra time to do the brake work.
The next person might know that "almost worn out brakes" could last another 10,000 miles because he drives on the highway a lot, or an alignment might have just been done a month ago. (Alignments should be done with the old tires either installed yet or available for the mechanic to "read" so he knows what adjustments are needed). If the car was recently aligned, that bad tire wear will remain for a long time, so it will be interpreted as needing an alignment if the mechanic doesn't know it was just done.
You might also feel threatened by the "it could fail soon" syndrome. Old, soft radiator hoses could spring a leak. This results in most people sitting on the side of the road in a puddle of tears. People like me know how to safely nurse the vehicle home or perform makeshift repairs on the spot. As a result, I don't replace anything until it's beyond junk! Imagine though how you would feel sitting on the side of the dark country road on a Saturday night with a popped hose and your mechanic did NOT warn you about it.
A lot of shops will inspect your car more carefully and find more things that need attention in an effort to prevent the unexpected breakdown. Consumers who know enough about cars to be dangerous are often penny wise and dollar foolish. Some shops might cater to that person by doing only the repairs requested and no more. Naturally their bill will be lower, but they get what they didn't pay for.
One final thought. It's best to stick with a shop you trust. People who bounce from shop to shop are always convinced the last one ripped them off. Regular customers at the dealership where I worked knew the mechanics by name, and there was less incentive to push additional services now because they knew they would be back in the future. There was no fear of losing that additional work to a competitor. A common saying at my shop was "it takes more advertising dollars to get one new customer that it takes to keep ten current customers happy". When shop personnel know they are likely to keep your business, they are more likely to continue trying to earn it.
Dealerships also keep a history record of your car so they know what work was done in the past. Since they have factory training, many jobs actually take less time. When it comes to a difficult diagnosis, all of their expertise pertains to your car. Mechanics at the better independent shops also seek out a lot of training, but they have to spread it out over every brand and model of car. When comparing them to doctors, dealership mechanics are like the specialists, and independent shops are more like the general practitioner. Both have their place, but don't you normally go back to the same doctor for every checkup? Even if they misdiagnose something once, it doesn't erase all the previous positive visits.
Caradiodoc
Wednesday, January 13th, 2010 AT 12:58 AM
LADY921
U definitely shed new light on the situation. I am not car literate at all. I don't want to be one of those people stuck on the side of the road. My mistrust of the dealership was due to them selling me a car and problems with the car began less than a month after financing it. Had I been more knowledgeable I would have made better choices. Since ur response, I have been reading the owner's manual to familiarize myself with my car a little better. I agree that taking my car to the dealership is like having a specialist. The mechanics are trained to repair my car specifically. So I thank you. I don't know how u are rewarded on this website for ur time and advice. Is there a comment page that I can speak about ur services? Will it benefit u somehow? Let me know because u have given me more information in a week than anyone I've spoken to about my car in the last two months. Thank u.
Thursday, January 14th, 2010 AT 7:57 AM
