2005 Chrysler 300 Sensors flash, gauges fluctuate when heat
2005 CHRYSLER 300
93,000 MILES • V8 • AWD • AUTOMATIC
GREAP3R
I don't know if this would be categorized under computers or what... But recently while I was on the highway (with the heat on) all the lights on the dash flashed on and the fuel gauge fluctuated. I tried driving without the heat on and it was fine. What's the problem? Does it have anything to do with a bad wire connection or what?
Oct 2, 2009 at 8:46 AM
  • 110,244 POSTS
Has the problem continued to happen? Also, have you checked to make sure all ground wires / body grounds are clean and tight?
Oct 20, 2009 at 1:01 AM
