where is the rear pinion seal and cause for possible leak?
Feb 23, 2010 at 6:30 AM
HMAC300
✓Experienced Mechanic
the pinion bearing is at the end of the driveshft. It can leak due ot many things, bearing bad, or just the seal bad. Have apro fix it if you 've never done one as you can screw up tightenning it and cause the bearings to fail..
