Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Chrysler
300
Engine
Symptoms
Overheat
2005 Chrysler 300 overheating and leaking
2005 CHRYSLER 300
94,650 MILES • 6 CYL • 2WD • AUTOMATIC
ROB1369
MEMBER
1 POST
car is overheating and small leak were top radiator hose goes into engine. where is the thermostat?
May 21, 2010 at 6:13 AM
Experienced Mechanic
Follow the lower radiator hose it will take you to the thermostat housing its behind it
May 21, 2010 at 3:02 PM
Add image or video
Ask a new question
Engine won't start
Check engine light
