2005 Chrysler 300 interior, outside lights dim/flicker
100,000 MILES • 6 CYL • 2WD • AUTOMATIC
RAYMOND1963
Once I start my vehicle the lighst start flickering, however eventually, the stop flickering and once I start rolling they start flickering again this are all of the lights, the radio still works, however it feels like the entire car is flickering.
updated 12/10/09
I have checked those and had the alternator rebuilt, also checked battery and is ok, now that is cold is realy acting up. How can the voltage regulator be replaced or fixed.
Nov 18, 2009 at 12:25 AM
  • 110,251 POSTS
It could be a poor ground. Make sure the battery ground to the engine block is clean and tight. Also, check body ground straps. FInally, if everything looks good, have the alternator checked. The voltage regulator may be going bad.
Let me know what you find.
Dec 7, 2009 at 2:57 PM
  • 110,251 POSTS
It is part of the alternator.
Dec 10, 2009 at 5:26 AM
