headlights and dash lights pulsing
104,500 MILES • 6 CYL • 2WD • AUTOMATIC
MARTINJR
when turning on lights and when switching from dim to bright the headlights and dash lights pulse at a rate of about 3-4 pulses per second. This also happens with less intensity when the brakes are applied or turn signals used. The pulsing usually diminishes or stops in a minute or so but it is taking longer lately. The car has been starting well in cold weather. I have checked all the battery grounds?
Dec 6, 2009 at 12:47 PM
  • 110,248 POSTS
I would check all body to chassis ground and if they are okay the PCM controls the alternator output which is what might be going bad. I would try a new alternator first though because the voltage regulator can be going out.
Here is a guide to help you
https://www.2carpros.com/articles/how-to-replace-an-alternator
Please let us know what you find.
Cheers
Dec 7, 2009 at 2:45 PM
