2005 Chrysler 300 FRont passenger window
85,000 MILES • 6 CYL • AWD • AUTOMATIC
4DEAD
Window will still function with both the door and driver controls but will only go up or down 2-3 inches each time the button is activated.
Is this a drive gear, motor or pressure on window in track issue?
What are the suggested solutions?
Oct 28, 2010 at 8:04 AM
SATURNTECH9
  • 30,869 POSTS
The most likely cause would be the motor but until you remove the door panel and have a look then you wont know for sure.
Oct 28, 2010 at 8:11 AM
