2005 Chrysler 300 fog lights factory will not light
STEWART V ROBINSON
Electrical problem
2005 Chrysler 300 6 cyl Two Wheel Drive Automatic 44k miles
after checking bulbs switch and continuity lights still will not function . The dash indicator light says there on but they 're not ,then after using a test light to check continuity the left socket appears to haave two ground circuits on i. bulbs appear to be ingood condition even swapped on out did not change condition. The test light tells me that power is leaving the switch and getting to the socket.
Feb 5, 2008 at 6:18 AM
2CARPRO JACK
  • 11,533 POSTS
Right side of engine compartment should be a fuse/relay/power module. Look for the fog lamp relay, try swapping it with the A/C relay to see if it is just the relay that is bad, if not get back to me and get your test light out
Feb 5, 2008 at 11:44 PM
