2005 Chrysler 300 Error Code P0406
71,000 MILES • 6 CYL • 2WD • AUTOMATIC
DVANHORN
I have a Chrysler 300 Touring and my engine light is staying on with the code p0406 EGR Position Sensor Circuit High. I have had a recent tune up with the plugs and coils being replaced but it has not helped. I would like to know how much it would cost if a dealrer fixes this issue including parts and labor? Can I do this myself or can I have a side competent mechanic do it for me for less?
Jun 4, 2010 at 12:38 PM
  • 31,937 POSTS
You need to replace the EGR valve on the back of the cylinder head, this can be tricky so get a mechanic to do this, you will not have to go to a dealer a competent mechanic can do this work.
mark (mhpautos)
Jun 4, 2010 at 12:52 PM
DVANHORN
Thank you, so how much can I expect to pay for a repair job like this at a competent mechanic?
Jun 4, 2010 at 1:34 PM
  • 31,937 POSTS
The valve is about $90. and allow around 1.5 Hrs labour, check local labour rates for this cost.
mark (mhpautos)
Jun 4, 2010 at 1:39 PM
DVANHORN
Thank you I will let you know how it turns out!
Jun 4, 2010 at 1:51 PM
