2005 Chrysler 300 engine failure
43,395 MILES • V8 • 2WD • AUTOMATIC
JBACA36
2005 chrysler 300C has four times stopped running while driving, shortly after filling up tank, within 1/4 mile each time. Cardealer can't reproduce much less fix problem..I checked on line blog and several others reported similar problem with engine stalling out...Help!
Dec 12, 2008 at 10:01 AM
  • 110,248 POSTS
Have you checked fuel pump pressure after a fill up? I question if there is dirt in the tank causing limited fuel to get to the engine. Check the fuel filter for dirt or evidence of contamination.
let me know what you find.
Mar 16, 2009 at 3:33 AM
