2005 Chrysler 300 car wont try to turn over
LENNOX5151
  • 2005 CHRYSLER 300
  • 6 CYL
  • 85,000 MILES
All lights and instruments light up. Hooked up diagnostic trouble code p0004-fuel volume regulator control circuit high. But this wouldn't keep car from attempting to start would it? Checked fuses, battery connects, tried on off with ignition but no codes showed up. Check engine light is on. Had car keys reprogrammed. Please help.
Monday, April 6th, 2009 AT 11:31 PM
  • 109,885 POSTS
Hi:
Have a helper turn the key to the start position while you check for power to the smaller wire on the starter. There should be 12 volts.
Let me know what you find.
Sunday, May 3rd, 2009 AT 7:26 PM
