2005 Chrysler 300 blower motor resistor broken
46,000 MILES • 6 CYL • 2WD • AUTOMATIC
MIKEKATULSKI
can you describe exactly how to remove this resistor? I have the new part but do not know if it is necessary to remove glove box for replacement. I know the replacement part is different for an 05 from an 04.
thank you,
mike
Nov 7, 2010 at 10:17 PM
WRENCHTECH
  • 20,760 POSTS
REMOVAL
WARNING:
* ON VEHICLES EQUIPPED WITH AIRBAGS, DISABLE THE AIRBAG SYSTEM BEFORE ATTEMPTING ANY STEERING WHEEL, STEERING COLUMN, OR INSTRUMENT PANEL COMPONENT DIAGNOSIS OR SERVICE. DISCONNECT AND ISOLATE THE NEGATIVE BATTERY (GROUND) CABLE, THEN WAIT TWO MINUTES FOR THE AIRBAG SYSTEM CAPACITOR TO DISCHARGE BEFORE PERFORMING FURTHER DIAGNOSIS OR SERVICE. THIS IS THE ONLY SURE WAY TO DISABLE THE AIRBAG SYSTEM. FAILURE TO TAKE THE PROPER PRECAUTIONS COULD RESULT IN ACCIDENTAL AIRBAG DEPLOYMENT AND POSSIBLE PERSONAL INJURY OR DEATH.
* THE BLOWER MOTOR RESISTOR MAY GET VERY HOT DURING NORMAL OPERATION. IF THE BLOWER MOTOR WAS TURNED ON PRIOR TO SERVICING THE BLOWER MOTOR RESISTOR, WAIT FIVE MINUTES TO ALLOW THE BLOWER MOTOR RESISTORS TO COOL BEFORE PERFORMING DIAGNOSIS OR SERVICE. FAILURE TO TAKE THIS PRECAUTION CAN RESULT IN POSSIBLE PERSONAL INJURY .
CAUTION: Do not operate the blower motor with the blower motor resistor removed from the circuit. Failure to take this precaution can result in vehicle damage.
1. Disconnect and isolate the negative battery cable.
2. Remove the glove box from the instrument panel.
3. Disengage the wire harness connector locking tab (1) and disconnect the wire harness connector (2) from the blower motor resistor (3).
4. Remove the two screws (4) that secure the blower motor resistor to the HVAC housing (5).
5. Remove the blower motor resistor from the HVAC housing.
INSTALLATION
1. Position the blower motor resistor (3) into the HVAC housing (5).
2. Install the two screws (4) that secure the blower motor resistor to the HVAC housing. Tighten the screws to 2 N.m (17 in.lbs.) .
3. Connect the wire harness connector (2) to the blower motor resistor and engage the wire harness connector locking tab (1).
4. Install the glove box into the instrument panel
5. Reconnect the negative battery cable.
Nov 7, 2010 at 11:50 PM
