2005 Chrysler 300
SHANE21
Engine Mechanical problem
2005 Chrysler 300 6 cyl Two Wheel Drive Automatic
my car shut down and wont start, what do I do
Oct 12, 2010 at 4:08 PM
  • 75,988 POSTS
Pick your own symptoms-comeback with the results.
**Cranks but no start condition:
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine at least 3/16 away from ground -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/COP/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
**No crank at all/nothing/nada:
Could be the starter, starter relay, clutch switch/park and neutral switch and ignition switch assuming the battery and connections are good.
Oct 12, 2010 at 5:23 PM
