Transmission problem
2004 Chrysler 300 6 cyl Automatic 72000 miles
My car has an automatic transmission but it also has an auto stick; while driving using the autostick, all of the lights came on (P,N,D,1,2,R) and the car started slowing down. I pulled over to the side of the road and looked at the manual and it stated that if this happens the car is detecting a problem and it will no longer allow you to use the auto stick. It states that once you cut the car off and restart it, it should reset itself. However, when i turned the car back on, the malfunction indicator light came on. Now, if i drive the car at about 70 miles an hour and have to make a stop, the car isn't switching gears properly. The RPM gauge goes over 3 and the cars starts decelerating and wont go past 30 or 40. It only happens if i have to come to a sudden stop. Do you believe that i need a new transmission?
Mar 10, 2009 at 3:41 AM
