2003 Chrysler 300 Warning light
58,000 MILES • 6 CYL • 2WD • AUTOMATIC
GBARTCHER
What does a ESP BAS warning light stand for?
Dec 6, 2009 at 11:46 PM
  • 110,248 POSTS
ESP/BAS stands for Electronic Stability Protection/Brake Assist System. There is a pulse registered at each wheel when the car is being driven. If a sensor isn't working properly, it will set this code. You will need to have the computer scanned to determine where the problem is originating.
Let me know if you have other questions. Also, if you have experienced any other problems since the light came on?
Dec 7, 2009 at 2:34 PM
