2003 Chrysler 300 IGNITION SWITCH
BONDERICK NARD
  • 2003 CHRYSLER 300
Other Category problem
2003 Chrysler 300 Engine Size unknown Two Wheel Drive Automatic 88870 miles
INGNITION KEY WANT TURN THE INGNITION SWITCH. HAVE CHECKED AND IT IS THE RIGHT KEY.
Saturday, January 12th, 2008 AT 8:51 AM
BLACKOP555
  • 10,371 POSTS
Try a new key. Is the steering wheel locked? If so rotate it hard to the left and try turning the key then trying it towards the right, if still nothing have someone rock the vehicle.
If that is to no prevail use soem graphite lock lube and sprayin in the cylinder and the key and tap on the end and put in the key and keep working it, if the tumblers still dont drop down then you have to change it.
Saturday, January 12th, 2008 AT 9:23 AM
