1999 Chrysler 300 kEY IGNITION
12,000 MILES • 6 CYL • 2WD • AUTOMATIC
P_AYLES
My key wont turn in the ignition of my car. It's never been this bad before, i've not been able to fix it. The weheel is also locked, how do I fix this myself without taking it to a repair shop?
Mar 5, 2009 at 3:26 AM
  • 110,251 POSTS
If the key doesn't turn, there is a problem with the tumbler. Try a different key, spray a light lubercant in the key hole (just a little) to see if that helps. If it doesn't chances are the tumbler will need replaced. Because of the air bag, I would recommend taking it to a trained tech because steering wheel and part of the steering column will need removed, and the air bag could be deployed if you make a mistake.
Mar 15, 2009 at 3:32 PM
