2003 Chrysler 300
2003 CHRYSLER 300
COREYB760
Tires and Wheels problem
2003 Chrysler 300 4 cyl
How long can you drive on a flat tire before its no longer useable?
Sep 23, 2008 at 6:16 PM
BLACKOP555
  • CAR REPAIR CONTRIBUTOR
  • 10,386 POSTS
driving on a flat is a bad thign to do.
how low on air was it? completely flat riddin gon rim? if so youll have to check the tire and make sure you didnt damage the inner shell, also check the rim and make sure you didntbend that up.
doing thats also a good way for hte bead to pop off the tire and you to have an accident.
id say maybe 10 miles on a flat is plenty to damage a wheel and rim pretty well.
Sep 23, 2008 at 7:25 PM
