2002 Chrysler 300 oxygen sensor
2002 CHRYSLER 300
TROLLY7
Engine Performance problem
2002 Chrysler 300 6 cyl Two Wheel Drive Automatic
how to replace the oxygen sensor.
Feb 20, 2010 at 1:25 PM
HMAC300
  • CAR REPAIR CONTRIBUTOR
  • 48,601 POSTS
you neeed a special tool to remove it due to the wires coming off of it. just disconnect the electrical and unscrew the correct one and replace it...
Mar 1, 2010 at 8:52 PM
AUTOMD
  • 50 POSTS
Use a generic code reader to be sure you need to replace the sensor. turn and remove the sensor. More often than not, you must get a specially made oxygen sensor socket. use freeze spray to help loosen it. Pass the new harness and sensor into place where your removed the other, using the manufacturer's instructions. Check the seal to be sure dirt and water cannot get in easily.
Mar 3, 2010 at 2:36 AM
