Air Conditioning problem
2002 Chrysler 300 M 6 cyl 180xxx miles
this question is about my sisters car, chrysler c, the air conditioning works amazing, so cold itll freeze you out in the heat of summer, but, its stuck on one speed. high. nothing happens when you try to lower the speed. the heating works as well. just stuck at high, im going to check the fuses tonight when i get home. what do you think is the problem?
also the speed control wont set? the light comes on when you hit the on button but wont set.
May 6, 2010 at 7:22 AM
