2001 Chrysler 300 turn signal
2001 CHRYSLER 300
12,000 MILES • 6 CYL • FWD • AUTOMATIC
DELIGUY916
i was just wondering how and where is the front passenger side turn signal bulb is and how do i replace it?
Feb 3, 2010 at 8:44 AM
ERNEST CLARK
  • 1,730 POSTS
Your turn signal bulb is located inside the headlight. You'll need to pop the hood, pull up two metal tabs that holds your headlight in place then pull the headlight forwards to remove it. (Be careful not to yank on the wiring)
Then twist the connector to the yellow bulb and pull it out of the headlight assembly. Remove the bulb and replace it with the new one.
Then assembly is the reverse of removal.
Feb 11, 2010 at 1:03 PM
