i have a 2001 chrylser 300m. The problem is after going on highway speeds and coming to a stop, rpm's drop and car stalls. It will start up right away with no problems. I have had the spark plugs replaced, a cleaner to clean out all the carbon, took the throttle body off that still had lots of carbon build up. I was told to take the EGR valve off and have that cleaned by hand and if that didn't work to replace the EGR valve. The Idle control motor was checked and is functioning properly. Does this sound right with the EGR valve?
Apr 19, 2008 at 12:05 AM
