My oil light on the dash flashes on when vehicle is at a stop.
Dec 19, 2008 at 8:26 PM
✓Experienced Mechanic
Hi there,
Check that the engine oil level is correct, and get the oil pressure tested with a mechanical gauge, if the pressure is up to specs, i would be replacing the sender unit, start here.
