2001 Chrysler 300 Intermittent brake warning light
110,000 MILES • 6 CYL • FWD • AUTOMATIC
BRIAKOCH
I have 300M and the brake warning light sometimes comes on when I press down on the brakes hard. Otherwise the brakes seem to working fine.
Any ideas?
Thanks,
Brian
Nov 8, 2008 at 4:16 AM
ZACKMAN
  • 4,202 POSTS
There is a level sensor in the brake fluid reservoir. Over time (assuming that you are not leaking brake fluid) as your brake pads are wearing thin (but not thin enough to the brake sensor), the fluid flows into the brake line, instead of staying in the reservoir.
You may add some brake fluid into the reservoir, but you really should have the brake pads checked.
Nov 20, 2008 at 11:17 AM
