I was on my way home doing about 70mph on the freeway when my car just died. The accelerator dropped to the floor and the engine cut off and the thermostat went all the way up. I pulled off and popped the hood. There was no smoke or steam. The belts were intact. I looked undeneath and there was nothing dripping. I checked all my fluids and all were topped off. I recently had the oil changed and a rebuilt transmission installed. I have no clue what happened. Can you give me an idea to start repairs?
SPONSORED LINKS
Thursday, November 20th, 2008 AT 8:08 AM
MECHANIC
Hi:
Have you checked for spark and fuel to the engine?
Monday, March 16th, 2009 AT 10:46 AM
ELO1994
MEMBER
No I have not. I haven't had a chance to check anything yet. First thing I will do is check the fuel pump, then the fuel lines. Next is the spark plugs and alternator. Should I check something else?
SPONSORED LINKS
Monday, March 16th, 2009 AT 10:53 AM
MECHANIC
The easiest thing to check is for spark. I would start there and move to the fuel pressure.
Let me know what you find. Also, I reread your post. What do you mean the accelerator fell to the floor?
