2001 Chrysler 300
KKOLLIOS
Transmission problem
2001 Chrysler 300 6 cyl Automatic 104000 miles
When decelerating my car jolts then gets stuck in first gear. I turn it off then on and the problem goes away for a few miles. Our mechanic said the check engine light says" stuck in first gear". He flushed and conditioned the trans. For a few months now I have also been having problems with my interior and headlights flashing. Also the radio station presets change? new battery 1 month ago and problem still persists. Could these problems be related? Maybe fuses or electrical system or separate trans problem? Anyone ever hear of this?
Sep 8, 2010 at 3:42 AM
ERNEST CLARK
  • 1,730 POSTS
Your transmission problems will be seperate from your electrical problems.
The PCM controls the tranny, the BCM controls your interior electronics and head lights.
There is a possibility your wires/harnes and/or the connectors are corroded or loose.
Either way, you'll need a technician very familiar with these components for an accurate diagnosis.
Do your homework before paying a shop to fix this. And your best bet may be a dealer.
Sep 14, 2010 at 12:57 AM
