when I am on snow it won't pull itself. I don't think the traction control works. What controls it? Is it vacuum controled?
Dec 17, 2007 at 9:31 AM
SDK_RACER
MEMBER
The traction control is controled by the abs and wheel speed sensors. If it detects one tire is moving alot faster than the others (spinning) It applys the brake to that wheel to slow it down.
Mar 18, 2008 at 10:08 AM
QUINN2
MEMBER
If the traction control is activating, an indicator light on the dash will come on that says "trac control" and you should hear a buzzing noise similar to the noise you hear with the anti-lock brake system (ABS).
