2000 Chrysler 300 traction control
88,000 MILES • 6 CYL • FWD • AUTOMATIC
NEALCUDA
when I am on snow it won't pull itself. I don't think the traction control works. What controls it? Is it vacuum controled?
Dec 17, 2007 at 9:31 AM
SDK_RACER
  • 9 POSTS
The traction control is controled by the abs and wheel speed sensors. If it detects one tire is moving alot faster than the others (spinning) It applys the brake to that wheel to slow it down.
Mar 18, 2008 at 10:08 AM
QUINN2
  • 6 POSTS
If the traction control is activating, an indicator light on the dash will come on that says "trac control" and you should hear a buzzing noise similar to the noise you hear with the anti-lock brake system (ABS).
Mar 25, 2008 at 12:48 AM
