2000 Chrysler 300 oil pan
14,000 MILES • 6 CYL • 2WD • AUTOMATIC
HANERC
dont have the room to take out my oil pan where did go wrong?
Aug 3, 2008 at 9:54 AM
MMPRINCE4000
  • 8,548 POSTS
In many cases you will have to lift the engine, or support it and take out any lower supports or mounts.
Buy a Haynes manual, it is probably the best investment a DIY'er can buy.
It will show the procedure and you can read the procedure before you start, which will give you insight into what you are getting into and any special tools needed.
Aug 4, 2008 at 10:04 PM
