2000 Chrysler 300 Oil Burner
100,500 MILES • 6 CYL • FWD • AUTOMATIC
SIDEKUTTER
Recently my radiator overheated. The antifreeze was oily and the car began spewing thick white smoke from the exaust. The car also shakes and is starved of power when the gas pedel is depressed.
Feb 1, 2010 at 8:15 AM
  • 110,248 POSTS
It sounds like you have blown a head gasket. The overheating may have caused the problem. However, the white smoke from the exhaust is the dead give away. Coolant burns white when it enters a combustion chamber. To confirm, check the motor oil to see if there is any coolant mixed with the oil. You mentioned the coolant appeared to have oil in it which is possible too. WHen the engine is cold, open the radiator and see if there is any pressure pushing the coolant out. Finally, if all else looks good, you will need to perform a compression test. Here is a how to for checking it. You will need a compression gauge. Most parts stores will lend or rent them.
https://www.2carpros.com/dia/how_to_check_compression.htm
Let me know what you find or if you have other questions, and thanks for using 2carpros.com.
Feb 1, 2010 at 10:39 AM
