2000 Chrysler 300 ignition issues
12,900 MILES • 6 CYL • FWD • AUTOMATIC
GOLDIE25
I am having a serious problem with my ignition, when I put in my key to start the key the ignition does not turn, it just locks up. I have been having issues with this for about 2-3 months. I usually just wotk with it and it sooner or later turns and fires up. This time it is completely locked up. what is the issue?
Dec 1, 2008 at 6:13 AM
  • 110,248 POSTS
If you have another keey try it. I have seen keys wear out. If it still doesn't work, chances are the tumbler is damaged. You can try a thin lubericant to see if that helps. If not, replace the tumbler.
Mar 16, 2009 at 3:37 AM
