2000 Chrysler 300 engine
115,000 MILES • 6 CYL • FWD • AUTOMATIC
TONY1965
  • 9 POSTS
My car started an ran smooth for 15 to 20 seconds then shut down , it did this a few times now it wont crank over by the key you can jump starter relay terminal and it will turn over i tried a new rely but didn't help, any suggestions would be greatly appreciated. Thanks
Jun 15, 2010 at 3:09 AM
DOCFIXIT
  • 18,828 POSTS
Hi
Pull starter relay not the three spade connectors in a row the furthest from row of fuses is term A from ignition. Use test light turn key to start does it light?
Let me know
Thanks for donate
Jun 15, 2010 at 6:03 AM
TONY1965
  • 9 POSTS
i had check that an yes the test light does light up with turning the key
Jun 15, 2010 at 8:44 AM
DOCFIXIT
  • 18,828 POSTS
O.K. go to last term in that row clip test light to BATT pos probe that term try and start does it light up?
Jun 16, 2010 at 1:16 AM
TONY1965
  • 9 POSTS
if i'm following correctly the terminal of the starter relay only lights showing key function when the test light is grounded
Jun 16, 2010 at 1:51 AM
DOCFIXIT
  • 18,828 POSTS
Yes first test verfied that so next test will tell if PCM is providing ground to close relay and operate starter
Jun 16, 2010 at 1:59 AM
TONY1965
  • 9 POSTS
i now understand what your doing an no i'm not getting a ground from pcm does that mean the computer is the problem
Jun 16, 2010 at 3:43 AM
DOCFIXIT
  • 18,828 POSTS
That's what I thought was happening PCM left rear engine compartment with OHM meter check from relay C to PCM connector # 31 tan/white wire if good then PCM. before that check fuse #13 at left side dash. Jumper between the two terminals above the three this will op. starter key on see if it lights
Jun 16, 2010 at 6:21 AM
TONY1965
  • 9 POSTS
I replaced pcm with used unit car starts again but shuts down after a few seconds don't want to fry another pcm any thoughts?
Jun 17, 2010 at 1:09 AM
DOCFIXIT
  • 18,828 POSTS
Maybe ASD relay when it dies does it start back up ? if not determine if spark or fuel is problem
Jun 17, 2010 at 7:57 AM
TONY1965
  • 9 POSTS
First of all thank you very much i cant tell you how much it help talking over this problem with you guys . I was amazed an relieved to find my problem was a remote starter control it wasn't read the chip in the key , i removed entire assy. took oem key out of controller an car starts &runs sweat .thanks again.
Jun 17, 2010 at 10:57 AM
DOCFIXIT
  • 18,828 POSTS
Great news was remote OEM or aftermarket? Want to remember this if it comes up down the road.
Jun 18, 2010 at 4:54 AM
TONY1965
  • 9 POSTS
it was an aftermarket set
Jun 18, 2010 at 6:23 AM
