2000 Chrysler 300 engine
TONY1965
  • 2000 CHRYSLER 300
  • 6 CYL
  • FWD
  • 115,000 MILES
My car started an ran smooth for 15 to 20 seconds then shut down, it did this a few times now it wont crank over by the key you can jump starter relay terminal and it will turn over I tried a new rely but didn't help, any suggestions would be greatly appreciated. Thanks
Tuesday, June 15th, 2010 AT 10:09 AM
DOCFIXIT
  • 18,828 POSTS
Hi
Pull starter relay not the three spade connectors in a row the furthest from row of fuses is term A from ignition. Use test light turn key to start does it light?
Let me know
Thanks for donate
Tuesday, June 15th, 2010 AT 1:03 PM
TONY1965
  • 9 POSTS
I had check that an yes the test light does light up with turning the key
Tuesday, June 15th, 2010 AT 3:44 PM
DOCFIXIT
  • 18,828 POSTS
O.K. Go to last term in that row clip test light to BATT pos probe that term try and start does it light up?
Wednesday, June 16th, 2010 AT 8:16 AM
TONY1965
  • 9 POSTS
If i'm following correctly the terminal of the starter relay only lights showing key function when the test light is grounded
Wednesday, June 16th, 2010 AT 8:51 AM
DOCFIXIT
  • 18,828 POSTS
Yes first test verfied that so next test will tell if PCM is providing ground to close relay and operate starter
Wednesday, June 16th, 2010 AT 8:59 AM
TONY1965
  • 9 POSTS
I now understand what your doing an no i'm not getting a ground from pcm does that mean the computer is the problem
Wednesday, June 16th, 2010 AT 10:43 AM
DOCFIXIT
  • 18,828 POSTS
That's what I thought was happening PCM left rear engine compartment with OHM meter check from relay C to PCM connector # 31 tan/white wire if good then PCM. Before that check fuse #13 at left side dash. Jumper between the two terminals above the three this will op. Starter key on see if it lights
Wednesday, June 16th, 2010 AT 1:21 PM
TONY1965
  • 9 POSTS
I replaced pcm with used unit car starts again but shuts down after a few seconds don't want to fry another pcm any thoughts?
Thursday, June 17th, 2010 AT 8:09 AM
DOCFIXIT
  • 18,828 POSTS
Maybe ASD relay when it dies does it start back up? If not determine if spark or fuel is problem
Thursday, June 17th, 2010 AT 2:57 PM
TONY1965
  • 9 POSTS
First of all thank you very much I cant tell you how much it help talking over this problem with you guys. I was amazed an relieved to find my problem was a remote starter control it wasn't read the chip in the key, I removed entire assy. Took oem key out of controller an car starts &runs sweat . Thanks again.
Thursday, June 17th, 2010 AT 5:57 PM
DOCFIXIT
  • 18,828 POSTS
Great news was remote OEM or aftermarket? Want to remember this if it comes up down the road.
Friday, June 18th, 2010 AT 11:54 AM
TONY1965
  • 9 POSTS
It was an aftermarket set
Friday, June 18th, 2010 AT 1:23 PM
