Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Chrysler
300
Engine
Symptoms
Overheat
1999 Chrysler 300 water leaking underneath car and overheat
1999 CHRYSLER 300
130,000 MILES • 6 CYL • FWD • AUTOMATIC
MAD21804
MEMBER
Car started overheating and when putting water in it is running out at the bottom as fast as putting it in. What could be the problem???
Aug 23, 2009 at 6:08 AM
Experienced Mechanic
Could be the radiator, bottom hose where exactly is it leaking at.
Aug 23, 2009 at 6:11 AM
MAD21804
MEMBER
It is leaking right above the transmission pan but it is antifreeze and water mix.
Aug 23, 2009 at 6:18 AM
Check the heater hose and freeze plugs and right along the cylinder head mating surface
Aug 23, 2009 at 6:22 AM
ICY360
MEMBER
It might be because the Plastic drain valve is in an open position on the bottom of the radiator on the left side from the front of vehicle.
Sep 3, 2009 at 10:36 AM
🔧 Tools & Auto Repair Parts
Shop on Amazon →
Add image or video
Ask a new question
Engine won't start
Check engine light
