1999 Chrysler 300 water leaking underneath car and overheat
MAD21804
  • 1999 CHRYSLER 300
  • 6 CYL
  • FWD
  • 130,000 MILES
Car started overheating and when putting water in it is running out at the bottom as fast as putting it in. What could be the problem?
Sunday, August 23rd, 2009 AT 1:08 PM
Could be the radiator, bottom hose where exactly is it leaking at.
Sunday, August 23rd, 2009 AT 1:11 PM
MAD21804
It is leaking right above the transmission pan but it is antifreeze and water mix.
Sunday, August 23rd, 2009 AT 1:18 PM
Check the heater hose and freeze plugs and right along the cylinder head mating surface
Sunday, August 23rd, 2009 AT 1:22 PM
ICY360
  • 25 POSTS
It might be because the Plastic drain valve is in an open position on the bottom of the radiator on the left side from the front of vehicle.
Thursday, September 3rd, 2009 AT 5:36 PM
