The car is a 300m. When changing timing belt I noticed that the cam end are round with a flat spot.
After replacing cam seals , i noticed the pulleys have
almost a complete timing belt tooth of play.
Is this normal, or should they slide on without any play?
Oct 11, 2010 at 5:26 AM
