1999 Chrysler 300 shaking when braking and at very low spee
1999 CHRYSLER 300
155,551 MILES • 6 CYL • FWD • AUTOMATIC
USERTIM2
I have chaged my front rotors and pads for the second time it has improved. However, im still getting a little vibration when braking between 45 & 65 miles per hour. Or when slowing down between 50 to 30 miles. At high speed slowing its fine. I have changed my rear pads but not the rotors. The slow wobble feels like a bent rim but i have told that my rims are fine. What do you think is the problem and do you get many questions about this problem for this car?
Aug 14, 2010 at 12:45 AM
MMPRINCE4000
  • 8,548 POSTS
You need to check the front ball joints, control arm bushings, and inner and outer tie rods. Possible front wheel bearing also.
Aug 14, 2010 at 1:35 AM
