1999 Chrysler 300 replacing starter
134,000 MILES • 6 CYL • FWD • AUTOMATIC
BIGFOOTSNO
where is the starter located
Aug 29, 2008 at 11:56 AM
BADBO
  • 35 POSTS
If it has a 3.2l or 3.5l it is between the catalyst and the engine mount. Find the catalyst. And to replace it you will probably have to loosen a motor mount and raise the engine a bit to have enought room to remove it. Hope this helps.
badbo
Aug 29, 2008 at 12:25 PM
