I am trying to find out where the radiator temperature sensor is located and how to install it?
Apr 13, 2009 at 7:33 AM
BLUELIGHTNIN6
✓Experienced Mechanic
Engine coolant temperature sensor is located on engine, in water jacket near thermostat housing. Disconnect electrical connections and remove mounting bolt(s) to remove and replace.
Thanks for using 2CarPros.com!
Apr 13, 2009 at 8:01 AM
