1999 Chrysler 300 poor accerleration
103,000 MILES • V8 • 4WD • AUTOMATIC
SPICE55
I have a 1999 chrysler 300. Lately when I am stopped and I proceed to drive, it feels as though I am not getting any acceleration for about a few seconds and then all of a sudden the car will just take off. I am good when I'm driving in traffic, it's just that at times this mishap happens. Sometimes also when I'm driving I feel as though I'm not getting enough acceleration. What do you think the problem is?
Oct 16, 2008 at 10:30 AM
  • 75,988 POSTS
Have the fuel pressure check, the throttle position and MAP sensors-checked out
Oct 16, 2008 at 10:45 AM
JASONRAY
  • 213 POSTS
It's possible that you're having some transmission problems. If the "check engine" light or "service engine soon" light is on, have the codes checked first. The reason I say the transmission is it could be not downshifting all the way to low gear when you come to a complete start. Once you start moving, something may trigger the PCM to shift into low gear and off you go. You also could have a problem with your TPS (throttle position sensor). The PCM relies on this sensor to tell it that you are pushing the gas pedal. It then adjusts the pulsewidth on the injectors, among other things to give you the maximum performance under those driving conditions. Again, check for codes and hopefully you'll at least get pointed in the right direction.
