1999 Chrysler 300 play of cam pulleys on camshafts
1999 CHRYSLER 300
160,000 MILES • 6 CYL • FWD • AUTOMATIC
DAN BUTTS
Y'all responded to my question from yesterday. But it
didn't answer my question. Should the cam pulleys move or have play on the camshafts? My pulleys will
move about 1 to 1.5 teeth without the cams moving.
When I aligned all timing marks and got belt tight the engine started and ran fine until 3800 to 4000 rpm and then started cutting out. I have trouble understanding how an engine can be perfectly timed if the cam pulleys have any significant play.
Oct 12, 2010 at 3:05 AM
DOCFIXIT
  • 18,828 POSTS
Cam pullys should NOT have any Play. Where cam sprockets removed?
Oct 12, 2010 at 6:20 AM
