1999 Chrysler 300 oil pressure fuel pump
1999 CHRYSLER 300
91,000 MILES • 6 CYL • 2WD • AUTOMATIC
MYFAMILY
my 1999 chrysler 300m is making a clicking sound when engine car is on and the oil symbol keep on blinking the original owner said that he had put a new rebuilt motor but the noise seems to be coming from the engine
Feb 5, 2008 at 5:07 AM
Check the actual oil pressure with an oil pressure tester. This will determine if the oil pump is failing/engine bearings/clogged pick up screen/low oil. Check the pressure and comeback with the readings.
Feb 5, 2008 at 5:15 AM
